40 dogtag template 50x28mm milled in aluminum
61 opens
17 copies
1 comment
JAMES ZAPETIS
JAMES ZAPETIS
NEWARK, US
40 dog tag aluminum template 50×28mm with center hole (to push tags out when done laser engraving) cut out of 12 × 12 inch aluminum. Similar to a wooden template I laser cut in the image. Decided to make out of aluminum due to warping when laser engraving not dissipating the heat.
JAMES ZAPETIS
The aluminum plate is 3.8 mm thick. And hole cut through to assist in removing the finished pieces after engraving.
JAMES ZAPETIS
