A decent sized 3D printer
Paul Kim
Paul Kim
A fairly large 3D printer made with makerslides, aluminum extrusions, acrylic, and 3D printed parts.
Aluminum Extrusion (20mm x 40mm) - Clear
Aluminum Extrusion (20mm x 40mm) - Clear (×2)
Length: 1500 mm
$57.32
Black Acrylic Sheet
Black Acrylic Sheet
Dimensions: 18 in × 24 in, Thickness: 1/4 in
Black PLA 3D Printer Filament
Type: Filament, Diameter: 1.75 mm, Material: PLA, Color: Black, Shade: Black, Spool Weight: 1 kg, 3D Printer Compatibility: RepRap
Dual Bearing V-Wheel Kit
Type: Wheels dont use 3, Qty: 20 Pack dont use 3
MakerSlide - Black Anodize - 5M Tapped (×2)
Length: 1800mm - 2012 - 2019
MakerSlide Tapping Kit
Contents: Kit includes tapping handle, M5 × 0.8mm tap, 11/64" jobber drill bit and cutting fluid, Type: Accessories
MXL Belting - Open Ended
MXL Belting - Open Ended (×15)
Pitch: 0.08 in, Width: 0.25 in, Length: 12 in (shipped uncut if more than 1' is ordered)
Plastic MXL Pulley - Dual Flange
Plastic MXL Pulley - Dual Flange (×6)
Bore: 5 mm, Teeth: 18
Stepper Motor - NEMA 17
Stepper Motor - NEMA 17 (×5)
Lead Time: In stock, Holding Torque: 62 oz/in
Stepper Motor Cable
Stepper Motor Cable (×10)
Length: 1 ft, Category: Accessory, Type: Cable
White Acrylic Sheet
White Acrylic Sheet
Color: White, Cut Tolerance: +/- 1/8 in, Dimensions: 18 in × 24 in, Opacity: Opaque, Surface Finish: Glossy, Thickness: 1/4 in, Thickness Tolerance: +/- 8%
$57.32
R. Shane Raney
What are you using for the extrusion head?
R. Shane Raney
Paul Kim
The nozzle is called the budaschnozzle, it is not as popular as some other nozzles but it is so far very reliable. since it is a open source design a number of vendors carry them, including Amazon but make sure you're getting the one with the right filament size.
Paul Kim
John Lewis
Paul, the printer looks great. I have a few questions: 1. Can you give me an idea of the quality of print? 2. Is it still in active use? 3. Have you modofied it since the original post? 4. Is this a reprap variant? 5. What software / hardware combo are you using? Thanks, JHL
John Lewis
ken fowler
WHERE ARE THE PLANS FOR THIS PROJECT LOCATED TANKS KEN
ken fowler
NASSER SHAHBOU
1. Can you give me an idea of the quality of print? 2. Is it still in active use? 3. Have you modified it since the original post? 4. Is this a reprap variant? 5. What software / hardware combo are you using?
NASSER SHAHBOU
Genny Swiss
I have always been a Lot excited about the 3D printers. Finally, I got the opportunity to go through this post. But One thing to ask Can we follow https://www.epsonsupport247.com/how-to-fix-epson-printers-common-problems-by-epson-printer-tech-support/ if the user faces any errors while using it?
Genny Swiss
