Adipose Fidget Spinner
3 opens
1 copy
414 downloads 0 comments
Greg Tanner
Greg Tanner
An Adipose fidget spinner inspired by Dr. Who
Adipose.svg
SVG of the Adipose
Edit the project for your material and preferences.
Make two copies of the project.
One copy will be for the face, which is cut with a 1/32 in. mill.
Delete the body and the holes.
Cut this first.
The other copy is for the outline, which is cut with a 1/8 in. mill.
Delete the face.
The three 1/4 in. hole around the outside are for threaded rod and cap nut weights. I am not sure if I would use these as weight if I did this again. They are a little too bulky. I would try something a little more low profile.
Set the material thickness to your thickness.
Cut this second.
Also check out the “Fidget Spinner Finger Pads” project that I also published to get the finger pads.
