Air Plant Holder #2
98 opens
25 copies
629 downloads 0 comments
Teams  Design
Teams Design
A lightweight acrylic frame for hanging small air plants. Eclectic ventilation and translucent materials allow full sunlight and easy access. Mix and match colors and designs for a stunning window collection.
Cherry Blossom Acrylic Sheet
$11.49
Glacier Acrylic Sheet
$11.49
$22.98
AirplantHolder_#2.svg
SVG File
CarveyAirplant_directions.pdf
Assembly instructions
Mill part
Clamp and secure material. Run the program with a 1/16th bit.
For the EASEL carving program you can use this Link
Cut out material
Using a small hand saw cut through the tabs on the sides of the design.
Bend
Using a heat gun slowly heat and bend the joints of the holder. The joints will heat up faster than the body of the piece and should be easy to move.
Thread and tie
Using hanging material of choice, make a knot to anchor and thread strand through the bottom. Use several smaller pieces to fasten.
Featured here:
1/4th inch brown leather
Geometric metal bead
Noose-head tie
For more detailed instructions check out the pdf :)
