Animal Toy Safari
Teams  Design
Teams Design
The Animal Toy Safari is all about building connections with friendly creatures and exploring your imagination. Once you have assembled all of the figures, have some fun using the pieces to create your own animals!
MDF Wood
MDF Wood (×3)
$9.00
$9.00
Elephant.svg
Elephant
Giraffe.svg
Giraffe
Rhino.svg
Rhino
Cut Parts
Choose an animal to cut out.
ElephantLink
GiraffeLink
RhinoLink
Make sure your material is secured to the cutting platform.
Push Parts Out
Next you’ll have to push the parts out from the side they were cut on.
The carving machine will leave small tabs.
This insures the parts do not disconnect from the cutting surface during carving.
Clean Parts
After pushing out the parts, there may be small bits of the
tabs still remaining along the edges of the piece.
If you’d like, file these down to get a nice, clean edge.
Assemble!
Using the pieces you just cut, assemble your animal!
Don’t forget to cut out the other figures.
Explore!
Once you have cut out and assembled all of the animals,
have fun exploring your imagination and creating your own animals!
Jason Bair
Could you make a bear like this please? That would be awesome. Thanks.
Jason Bair
VICTOR
bit diameter??
VICTOR
Teams  Design
Hi Victor, we used a 1/16 Fishtail bit. The Easel links have been updated and now include all the info you need. Thanks for your question.
Teams Design
ford bohl
try to make your design but i can not make tabs looks like fun but tabs are not there even if i add more can you help please
ford bohl
Ross Brinkman
Hi Fordnbohl, if you open the file using the Link in step 1, the tabs will be included. If you are uploading the SVG file into Easel, you will need to manual input the tabs yourself. We suggest using the following dimensions: Length: 0.17in, Width: 0.06in, Number of tabs: 3. We hope this helps!
Ross Brinkman
