Artist Palette Cutting Board
0 opens
0 copies
1069 downloads 2 comments
Samantha Alaimo
Samantha Alaimo
Chicago
The Artist Palette Cutting Board makes the perfect surface to slice and serve appetizers for a party or a small meal. The ergonomic handle allows you to carry it with ease.
Bamboo Plywood
Bamboo Plywood
Thickness: 3/4 in - don't use, Plies: 3 - don't use 1, Dimensions: 8 in × 12 in - don't use 1
pallet_cuttingboard.svg
The .svg file for the cutting board
Open In Easel
Click the “open in Easel” button above
Pick material in Easel
Choose a material and make sure to change the material and material dimensions in Easel.
Clamp Material
2 minutes
Clamp down the material. Make sure you won’t hit the clamps when you start carving!
Carve!
Once you pick your bit (1/8"is what I used), click the “carve button” and begin your carve!
Finishing
I used an 1/8 in chisel and rubber mallet, to knock the tabs off of my piece. Then I lightly sanded it with 220 sand paper.
Douglas Poston
what kind of "dremel" type of motor is used/shown for cutting?
Douglas Poston
Chelsea chauffeurs London
Here are some important Crosscars taxi services you need to keep in mind. https://crosscars.co.uk/Mitcham-Taxi https://crosscars.co.uk/Mitcham-Minicab-booking https://crosscars.co.uk/battersea-minicab https://crosscars.co.uk/Gatwick-Minicab
