Barnacules Nerdgasm Contest Fidget #1
34 opens
4 copies
2 comments
Jerry Berg
Jerry Berg
I used the fidget app to create a basic fidget then manually expanded on the design using the easy tools in Easel. Total time to create this design was about 10 minutes and it works pretty well and actually fits in the hand despite having so many bearings.
Thanks,
Jerry
http://barnnerd.com
Sealed Bearing - 8mm x 22mm x 7mm
ID: 8 mm, OD: 22 mm, Thickness: 7 mm, Type: 608-2RS
White ABS Plastic Sheet
Dimensions: 8 in × 12 in don't use, Thickness: 0.25 in don't use
Position Material Correctly
Make sure you position the material hold down clamps so they don’t interfere during cutting, I made that mistake on my first pass.
Jerry Berg
I'm quite proud of my 9 bearing fidget spinner!
Jerry Berg
jimi257
hi im pore i wish i can just have one i can make money from selling the spinners
jimi257
