Calibration Test Pattern
3324 opens
2022 copies
7473 downloads 9 comments
Robert Rieke
Robert Rieke
Los Alamos, NM
A 3″×8″ pattern designed to check the X-Carve or other hobby CNC for indications of stepper motor lost steps, improper stepper motor calibration, and lack of perpendicularity between the spindle/router and wasteboar.
CNC Calibration Test Pattern - MWP V1-1 121415.pdf
Open PDF Procedure
100 minutes
Attached to this project is a 6-page PDF that contains a description, procedure, measurements, and a data sheet for use.
To perform the calibration test, open the PDF and follow the procedure inside.
Charles Stevenson
Nice project! :-) Mine came out fantastic. Really put the mind at ease. Thanks for creating this detailed howto!
Charles Stevenson
Kirk Marchant
Robert, found a few issues that needed to be corrected. Really appreciate having a resource like this. THANK YOU!
Kirk Marchant
Tomer Amarilio
The PDF seems to be deleted. Do you mind posting it again?
Tomer Amarilio
Kenneth Maddux
No PDF? Anyone have??
Kenneth Maddux
Martin Metras
Here it is! I found it http://easel.inventables.com/projects/W5aNZfym_u2juTaPbJE8rA
Martin Metras
Jonathan Haywood
Can't seem to access the PDF. Mind Posting it again?
Jonathan Haywood
LD HENDERSON
No PDF
LD HENDERSON
Michael Ettman
PDF file for Calibration Test https://docplayer.net/50743481-X-carve-cnc-calibration-test-pattern.html
Michael Ettman
Jason F. Posey
docplayer.net pdf is blacklisted on avast FYI
Jason F. Posey
