Classic Slingshot
253 opens
73 copies
599 downloads 2 comments
Beyond Design
Beyond Design
Chicago, Illinois
A classic Y-shaped slingshot made of walnut, cork, rubber bands, and rope. Launch anything from ball bearings to foam darts to custom CNC’d ammunition!
Natural Cork Sheet
Natural Cork Sheet
Dimensions: 8 in × 12 in, Species: Cork, Type: Sheet, Thickness: 1/8 in
6" × 12" × 3/4" Walnut
$11.43
$11.43
slingshot.svg
Mill Slingshot and Plugs
First step is to cut the slingshot and plugs from 3/4" material. We used Walnut because it went nicely with the rope for the grip and the cork sling.
Use this EASEL link
Mill Sling
Mill the sling out of a flexible material. We used 1/8" cork from the Inventables store. Foam, rubber, or handcut cloth could also work for this piece.
Use this EASEL link
Sand, Finish, and Assembly
File/sand off whatever tabs remain and finish the walnut parts with mineral oil. To use a rope as a grip, wrap it around the inset part of the handle and use the provided hole to tie off the knot. Add a loop for convenient carrying. We used large O-rings as the elastic, but rubberbands will work too. Whatever you use, loop it around the plugs and pull it through the hole. The force on the elastic will only pull it tighter.
Xavier L
gonna get my brother with this
Xavier L
Philip Allen Stoeppelwerth
way to cool. ty
