CNC Clamp and Tool storage
7512 opens
4217 copies
39 comments
This is an all in one Clamp and Tool storage tray at 10 in x 12 in. It can hold up to 46 cutting tools . The tray is also equipped with a location for your 17 mm wrench and 150 mm caliper set. It will also hold all the hold down screws, clamps, and bases from the Inventables 3D clamp set.
Fabio Alves
I cant open it ... it says that it's not public
Fabio Alves
Matthew McCroskery
Very cool design! I'd like to make one, but your design has not been made public.
Matthew McCroskery
Matthew J. Parker Sr.
I went into edit and it is telling me it is Public. I am not sure what is going wrong.
Try now I just put a license on it. Maybe that was it.
I figured it out. I needed to Share it on my Easel. You should be able to download now.
Galen Stevenson
Thank you for this!!! I just got my XCARVE today (finally) and wanted something to do as a test-carve... and since I have all these clamps and accessories, it is PERFECT to carve this design to keep it all organized. THANK YOU again! :)
Galen Stevenson
Your so very welcome Galen. I wanted to make this right away but I ended up getting to busy making signs for my B&M business. So finally I got around to making this tray. I had a friend tell me this was next level OCD.:) So welcome to the club and enjoy your Xcarve. Happy cutting...
Zach or Sarah Harner
By the time this gets to the 3rd clamping tool, its already shoved my bit up into the collet, and from there, it keeps making things more and more shallow. Any idea what I can adjust to make this stop happening? I have went through 4 boards now trying to cut this design out.
Chris Zeppieri
I just gave this cut a shot and all of my shapes wound up about .050 too small.... Can anyone give me some advice on how to remedy this?
Chris Zeppieri
Brian Fleig
Thank you for this, I should have my first machine up and running tomorrow and this will be my first project. :)
Brian Fleig
Bennie Holcomb
Thanks for this! Put the result up top!
Bennie Holcomb
Damon webb
What bit did you use?
Damon webb
I used a .125 2 flute endmill to cut this out.
Brett O'Neal
thanks for the design worked out well
Brett O'Neal
Chadwick Kyle
this didn't work out to well for me. I used the exact measurements and hardly any of the holes were big enough. They were slightly too small. Thanks though
Chadwick Kyle
Zach hall
I am super excited, I ordered my Xcarve this morning and this will be my first project!! Cant wait to get everything and set it up!! This community is awesome!!
Zach hall
Alejandro Coleman
not exact dimension but will do
Alejandro Coleman
John Putz
Thank you for this. I received my X-carve this past Wednesday and can't wait to start using it.
John Putz
Matt Schlosser
Thank you for this design! I just got my X-carve yesterday and this was the second project I did. turned out great.
Matt Schlosser
Some people are having trouble with the tool bit holes being small. It will not hurt to select them and make the size .15inch. This will give plenty of room for your tool shank.
Douglas  Heath
Thank you, you are truly a saint!
Douglas Heath
Petros Mendonis
Thanks, this was so convenient to be able to have my clamps in order !!
Petros Mendonis
Jerry Moreno
What thickness does the board have to be. Thanks
Jerry Moreno
Kristi Allen
Carve stopped in the middle of the project. This is my first project...any suggestions?
Kristi Allen
Sean Cottman
thanks a lot for this!!!!
Sean Cottman
Thomas Berryhill
How do you select the holes to make them larger? Also, how do i lengthen the holder for my calipers? It is about an 1/8 inch too short. Yep. I’m a newbie.
Thomas Berryhill
Randall Hebert
I did a partial sample then a text file that I wanted to do then I made one of these. It shows me how much slop I have in my setup. Will tighten everything up then remake this with better wood. Used pine board I had so that may have added to the slop. Thanks to those who put this together.
Randall Hebert
Shannon Smolinski
I cut this a couple days ago...no luck my supplies did not fit into any of the slots. Only the calipers fit and the wedges... :(
Shannon Smolinski
Gregory Bandurske
nice! thankyou
Gregory Bandurske
Donald Yahnke
whats the best bit to use for this
Donald Yahnke
Eric Humbert
Carved this whole thing out and most of it is too small to accept the parts. Is there an updated version?
Eric Humbert
Randal Mansell
the depth of the cuts was not consistent. I had to go in and manually reset cuts for some of the pockets. it left out all of the holes for the clamp screws.
Randal Mansell
Vijay
everthing fits quite snugly. thank you for sharing. no need to widen anything.
Vijay
Brian Shinta
Hi Matthew, did you use any special software to scale the objects? Im currently trying to foam inlay my tools, but pictures aren't to scale. Thanks
Brian Shinta
Brian Shinta I just used easel to adjust the size to fit my tools.
Mike Beard
Getting ready to do this.
Mike Beard
NEGARA303
[b][url=https://negara303.store/]LINK NEGARA303[/url][/b] [b][url=https://rtp-negara303.store/]RTP GACOR NEGARA303[/url][/b] [b][url=https://clareng.com/?content=promosi]LOGIN NEGARA303[/url][/b] [b][url=https://negara303.shop/?content=slot]NEGARA303[/url][/b]
NEGARA303
NEGARA303
https://negara303.store/ https://clareng.com/?content=promosi https://negara303.store/
NEGARA303
NEGARA303
NEGARA303
