CNC Controller Panel
Bart Dring
Bart Dring
This is a demo project to show some of our new connectors. The text was engraved into the blue on white 2 color acrylic using a laser cutter.
Blue on Bright White Laserable Acrylic Sheet
Dimensions: 8 in × 12 in, Thickness: 1/8 in, Thickness Tolerance: ± .005 in
$15.00
DC Jack, Panel Mount
Size: 5.5mm × 2.1mm, Mounting Hole: 12mm, Max Depth: 18mm max.
Molex Microfit Connector Kit
Molex Microfit Connector Kit (×2)
Circuits Arrangement: 2 × 2
$15.00
conn_panel.ai
Adobe Illustrator
Brian Boatright
I've tried to open the .ai file you provided in VCarve Pro and it said it contained no vector elements, opening with adobe reader rendered a blank page. Could you post it as a vector file in another format? Also how do you determine the proper size for the molex connectors?
Brian Boatright
