CNC Hangboard
0 opens
0 copies
1144 downloads 8 comments
Wenray Wang
Wenray Wang
Sydney, Australia
I’ve really been getting into bouldering and indoor climbing recently with some friends, and decided to make this as a gift – buying a timber hangboard is really expensive in AUS (~$200) so this was a much more cost efficient solution.
Download Fusion360 file here: https://a360.co/2Zf2XDm
Hangboard_Cut_1.nc
Finger holds
Hangboard_Cut_4.nc
Outer edge
Konstantin Dolgan
What wood did you use?
Konstantin Dolgan
Wenray Wang
Hi Konstantin, I made this one in merbau - relatively cheap hardwood to source in Australia
Wenray Wang
Jonathan Solís
Is there a bit you would recommend for this project?
Jonathan Solís
Wenray Wang
I'd recommend a single flute 1/4 bit for this one - I find I'm able to push the single fluted bits faster and deeper on the X-carve to reduce cutting time, even if there is a bit more tearout along the edges
Wenray Wang
Arjan Dexters
Hi, thanks for sharing the design. I am curious to know how you attached the board to the wall? There doesn't seem to be a lot of space left at the edges for screws and such....
Arjan Dexters
Wenray Wang
Hi Arjan - I just drilled and screwed through the actual finger holds themselves, one in each corner
Wenray Wang
Arjan Dexters
okay, makes sense. Thanks!
Arjan Dexters
Andrew Huh
The link does not work
Andrew Huh
