Coffee Capsule Stand
47 opens
26 copies
1 comment
Jessica Rochefort
Jessica Rochefort
A quick, affordable and easy way to display coffee capsules.
Birch Plywood
Birch Plywood
Materials needed
Plywood – 4 mm (remember to measure the wood thickness, my plywood ended up being 4.2 mm!)
Sanding paper.
Carving and assembly
Secure the plywood to the waste-board.
Carve the two pieces.
Unfasten the clamp and remove pieces.
Sand the edges and tabs gently.
Assemble by slotting the two pieces together. The fit ought to be loose, as there needs to be some play for the stand to lean backwards. The groove-slots can be carved more narrow if you would like the stand to be more upright.
More info
If you would like to jazz the build up a bit – you can use the following link:
http://easel.inventables.com/projects/rldc_LrP0wCXlscpptwV2A
Bill Holland
It's not public, can you share your easel plans?
Bill Holland
