I Designed this coffee table using Fusion 360,
the material used MDF 2 sheets 600×600×6mm for this project,
I am working now to do the final prototype using 12mm MDF thick
laminated by wood veneer
No Derivative Works — You may not alter, transform, or build upon this work.
The author’s moral rights;
Joyie Joyie
Jalal Arbid
