Dimensions: 12 in × 24 in, Type: Roll, Species: Cork, Thickness: 1/16 in
These look really sharp. What did you use to adhere the 2 materials together?
Jeff Talbot
Thanks for the kind words Jeff. I used hot glue.
Matt McCoy
Hi Matt! Great work!I received an order for cork magnets. I have a laser engraver and am trying to achieve the same look as your coasters in regards to the engraving and charred edges.Was that all done by your laser because someone at Inventables is saying it won`t work?Thank you so much!!
Sadia Khan
Thank you Sadia. I used a 40W laser to engrave and cut the both the cork material and the plywood.
Hope this helps.
Matt McCoy
Hi Matt! Thank you so much! The magnets turned out beautiful!
Sadia Khan
That's great to hear Sadia. Happy I could help.
Matt McCoy
Jeff Talbot
Matt McCoy
Sadia Khan
Matt McCoy
Sadia Khan
Matt McCoy
