Desktop Planter
1073 opens
235 copies
977 downloads 8 comments
Beyond Design
Beyond Design
Chicago, Illinois
A small fun desktop planter made from 3/4 inch maple and black corian.
Black Corian®
Black Corian®
Dimensions: 10 in × 12 in, Thickness: 1/2 in, Cut Tolerance: +/- 1/2 in
Hard Maple
Hard Maple
6" × 12" × 3/4" Hard Maple
carvey planter.svg
carvey planter legs.svg
Mill base and stand
First we cut the corian parts for the base and stand of the planter. These can be done with either an 1/8th inch bit or by starting with a 1/4 bit to mill away the bulk of material and then refining with an 1/8th inch
Use this EASEL link
Mill reverse side of base
For this step you will want to flip the corian sheet over and align it to cut the reverse side of the circular puck part. This recess is to allow room for the joinery between the legs.
Use this EASEL link
Mill walls of planter
These rings will make up the walls of the planter. A fishtail or square ended bit is best for this cut. This will allow the steps to turn out crisply.
Use this EASEL link
glue, sand, and finish
Once your side walls are cut you can glue them together. When the glue has set you can then file the slots if needed and sand the exterior walls.
Jene Johnson
Can this be made with x-carve?
Jene Johnson
Jene Johnson
Can all of the Carvy projects be made on x-carve?
Jene Johnson
Paul Kaplan
Yup, Easel works with X-Carve and Easel.
Paul Kaplan
aaaaaa
aaaaaa
aaaaaa
How do you delete my comment?
aaaaaa
Colby Hysten
I opened the file but it only features the stand. There is no pot or am I missing something.
Colby Hysten
Germanly Irish
Colby, it says the rings make up the walls of this planter. :)
Germanly Irish
Keith Strahan
Neither of the files in the zip appear to include the rings for the planter.... at least when opened in Easel Pro.
Keith Strahan
