DeWalt 611 Vent Shroud
Corey Donaldson
Corey Donaldson
Vent shroud to redirect the DeWalt 611 Router air vent upwards.
Used mainly to stop cutting fluid from blowing away when engraving/cutting Aluminum.
Easily removable (just slips on/off), full tool change access, transparent (acrylic) for light through, fully SuckIt compatible.
Carbide Tip Ballnose 2 Flute - 1/8 in Cutting x 1/8 in Shank
$5.29
Carbide Tip Upcut 2 Flute -  1/4 in Cutting x 1/4 in Shank
Cutting Diameter: 1/4 in, Cutting Length: 3/4 in, Shank Diameter: 1/4 in
$40.45
$45.74
Vent Shroud mk2.step
3D Model step file of the shroud
1-Internal Roughing.nc
G-Code to roughly mill out internal pockets. Post-processed to run X-Carve through Easel.
2-Internal Shallows.nc
G-Code to get into the bottom where the 1/4" tool couldn't fit. Post-processed to run X-Carve through Easel.
3-Interal Bottom Radii.nc
G-Code to for internal radii. Post-processed to run X-Carve through Easel.
4-External Profile.nc
G-Code to remove all external material. Post-processed to run X-Carve through Easel.
5-External Finishing.nc
G-Code for optional finishing passes out outside perimiter. Post-processed to run X-Carve through Easel.
Milling Setup Sheet.pdf
Milling setup sheet with info needed for all milling operations.
Any Questions?
Sorry guys, I started writing detailed instructions, but lost it all before clicking save. So here’s a summary.
- Setup sheet has all the tool and material details, and machine settings.
- G-codes provided for those that just want to make it. No mess, no fuss. Just follow in order and follow the setup sheet.
- Step file provided for those who want it.
- Acrylic is best glued down to a piece of sacrificial MDF, so you can go to town on it without clamps getting in the way.
- Youtube link shows some of the first milling operation.
- Also, I lied about the “no mess”. There’s lots! I highly recommend some kind of vacuum boot.
I’m happy to answer any questions if you need more info!
Cory Borgel
could you post your fusion file? I need to adjust the material thickness for my material. Also, your step file just opens a txt file in the browser and wont download the step. Thanks for any help!
Cory Borgel
Corey Donaldson
No stress, mate. You can download it here >> http://a360.co/2uZf7Rd I also recommend drilling and tapping a screw through a thick side to secure it in place. The shroud fell off one time, and smashed to bits.
Corey Donaldson
Cory Borgel
Thank you Sir! Much appreciated! I was wondering how well it stayed on the router. a set screw is a good idea.
Cory Borgel
Mike Larsen
Very cool idea.
Mike Larsen
