This tool will hold the yellow spindle button in while you tighten or loosen the collet nut. That way there is less chance of moving the X or Y axis by mistake.
Key measurements: the inner diameter needs to be 2.700. The width where the flat is needs to be 2.565.
The author’s moral rights;
Kenneth Miller Jr
kody schaefer
Brock Price
Pedro Bolito
