DIY Corian + Walnut Trivets
71 opens
16 copies
Amanda Lynn Hendrix
Amanda Lynn Hendrix
These cute corian and walnut trivets are easy to make and are sure to make you smile the next time you’re serving up a big dinner!
$5.99
Carbide Tip V-Bit 90 Degree - 1/4 in Cutting x 1/8 in Shank
Cutting Diameter: 1/4 in, Tip Angle: 90 Degree, Shank diameter: 1/8 in
$21.40
Walnut (×2)
6" × 12" × 1/2" Walnut
$21.72
White Corian®
White Corian®
Thickness: 1/2 in, Dimensions: 8 in × 12 in, Cut Tolerance: +/- 1/8 in
$49.11
Carved Wood Trivet
- Use 90-degree V-Bit to cut pattern in wood
- Use 1/8" straight-end bit to cut circle
- Lightly sand, and add mineral oil
Corian + Walnut Stripes
- Cut 1" pieces of corian and walnut (I used a miter saw)
- Glue into stripes using silicone adhesive
- Once dry, use 1/8" straight-end bit to cut out circle.
- NOTE: You could adjust the shape to any shape you like, or carve into this one as well!
- Sand and add mineral oil
Carved Corian + Walnut
- Carve geometric pattern into corian
- Cut out corian strip using miter saw (if carving into a larger piece of corian)
- Glue between two equally-sized pieces of walnut using silicone adhesive
- Once dry, sand and add mineral oil.
- NOTE: You could also cut this one into a circle, if preferred
Made one? Log in to add yours
