DTC Table Saw Push Stick 1
54 opens
27 copies
Paul J. Bennett
Paul J. Bennett
Milbridge, US
Make your own table saw “push-stick” with FREE PLANS! Your fingers will thank you for it!
Cut Material to Size
Cut plywood to size (14″ × 8″).
Position Plywood on X-Carve and Carve"
Position the plywood on the X-Carve machine and let er’ rip!
Remove and Finish
Remove piece from X-Carve, cut the tabs to release the part, and finish with sand paper. Apply a couple of coats of Shellac. Your done!
