The looped square icon is ubiquitous with the Command key on Apple computer keyboards. I made this design as the first project I cut on my CNC machine using stock 3 1/2 inch wide, 1/2 inch thick oak from the big box store. It’s a simple 11 minute cut you can make with a flat cut bit.
The author’s moral rights;
