Easy Bevel Design
50 opens
10 copies
841 downloads 4 comments
Paul Kaplan
Paul Kaplan
Very quick cut with a v-bit makes for a cool bevelled design!
Baltic Birch Plywood
8" × 12" × 1/8" Baltic Birch Plywood
Carbide V-Bits
Carbide V-Bits
$15.77
ER11-A Collets and Nuts
ER11-A Collet 1/4in
$7.17
$22.94
christmas-tree.svg
Tree SVG
Load up the design in Easel
There are no special settings you need for using a v-bit for a simple bevel like this in Easel. Simply choose “Outline → On Path” and the v-bit will trace your design giving it a cool bevelled edge.
Choose a V bit
Depending on the look you want, you can try different angles of bits. There are 2 different angles available in the 1/4" collet size, and also a v-shaped engraving bit available for 1/8" collets.
Carve it!
I got to use the Carvey prototype to make this. It was incredibly simple, really just hit carvey and it carves!
Paint it
I added a splash of color by dipping it in an can of paint that I had laying around. Give the edges a few strokes with some sandpaper and you are done!
Done!
I always thought it was cool to see cut out pieces set up inside where they were cut out from.
Kyle Acker
Thanks so much for this! I'm going to use this design for christmas cards!
Kyle Acker
Paul Kaplan
I'd love to see the results!
Paul Kaplan
Mike Johnson
what diameter bit do you select w/ a V bit?
Mike Johnson
Mike Johnson
in Easel that is. (didn't see how I could edit my just posted comment)
Mike Johnson
