See image below for a depth reference
1. Open the project in Easel
2. Put the material lined up on your X-Carve to be cut
(Stock size: ¾” x 6” x 10”) and use the following settings for your material
(Also see images for reference):
Hard woods, I used 28 in/min with 0.030” for depth/pass
Soft Wood/Plywood, I used 30 in/min with 0.035” for depth/pass
4. Set your machine settings to use the bit you have available bit Size
i. 1/8” (0.125) = 3 hours plus cut time
ii. 1/4”(0.25) = 45min to 1 hour cut time
3. Verify the depth and cut settings
1. Click “Carve” in the upper right corner of the screen and verify the settings
+ Material Thickness
+ Secured Material
+ Bit size
2. Set your home position to the bottom right of your work piece, raise the bit & turn it on
3. Run the X-Carve, sit back and watch the magic! (Wear hearing protection)
1. With a tool of your choice, cut the parts following the outline cut in Step 1.
3. Fit the two parts together with the top of the pen facing left for the lid and base.
4. Shape them together to desired look
5. Sand to 320 grit and Finish
Chad Forrester
Jason McGinn
Tim Vannaman
Tim Vannaman
Sam Gironda
travis Brenden
travis Brenden
Lawrence McCartney
Kevin D. Hanning
