Flipbook Machine
121 opens
45 copies
4 comments
Cristiana Felgueiras
Portugal
Fun project and way to develop creativity at several levels.
You can make the machine itself and make sequenced drawings by hand, digitally or use a video and print some frames from it.
Also, this makes a super cool gift!
$5.99
Clear Acrylic Sheet - Cast
Dimensions: 8 in × 12 in, Thickness: 1/8 in, Material Type: Cast
$5.99
Grey MDF Sheet
Grey MDF Sheet (×5)
8" × 12" × 1/4" Grey MDF Sheet
$55.55
$6.49
$74.02
Build it!
Watch the video and see all the building process.
Be aware that I actually used 8mm thick grey MDF and you might only find a thinner thickness on Inventables store so you need to remake the box using the Box Maker App on Easel once you select your bit size, material and material thickness so the box joints come up perfect.
John McWhirter
Dope project!
John McWhirter
Megan Palmieri
I finally made one! Thanks for sharing!
Megan Palmieri
Dani
Alguien sabe el tamaño de las hojas?
Dani
