full rubber band carbine
80 opens
26 copies
sam
sam
st petersburg, fl
google search will bring up a video of how to cut/make it with a scroll saw… just brought it to cnc with the help of one other to make the files functional. modified pieces some for a better feel/sturdier for kids to play with.
Baltic Birch Plywood
12" × 12" × 3/4" Baltic Birch Plywood
Button Head Cap Screw
Button Head Cap Screw (×2)
Length: 12mm, Quantity: 10, Thread Size: M5
Chicago Screws
Chicago Screws (×3)
Material Thickness Range: 1/4 in - 3/8 in, Barrel Length: 1/4 in
Natural HDPE Sheet
Natural HDPE Sheet
Thickness: 1/2 in don't use, Dimensions: 8 in × 12 in don't use
cut out 3/4 pieces.
90 minutes
cut out all 3/4 pieces.
i use a 1/4 bit and cut on the outside of the path.
i switch to a 1/8 bit to mark the holes and hand drill them. my 1/8th inch bit is only 3/8’s of a inch long.
cut out 3/8th pieces.
16 minutes
move the 3/4 inch pieces to the side and bring the 3/8th pieces into the cut area. then carve them out.(need both plates)
cut out with a 1/8th inch bit
cut the plastic.
6 minutes
move the 3/8th pieces to the side and bring the plastic pieces into the cut area. then carve with a 1/8th inch bit
plastic i use is a cutting board from walmart. its right under 3/8th thick and works for all of the rubberband guns i make.
sand
sand the burs and thin the trigger/mag down a little so it moves freely when assembled.
the plastic t needs a 45 cut in the tip of it. i just push it against my belt sander. no accuracy needed. just has to fit inside the star wheel to make it single fire.
round the edges of the star a bit so it doesnt cut the rubber bands.
assemble
7 screws are 1/2 inch long on each side
the chicago screws are 1 1/4 long cannot select length in parts list.
the 3 holes for the chicago screws need to be adjusted to fit the post size you can find.
top center of the trigger needs drilled so a screw can go threw the plastic T to make select fire work.
keep this only finger tight so it can spin so it can go full auto or single fire.
if the mag is larger it fires at a slower rate. smaller makes it fire faster.
google
google rubber band carbine and there are youtube videos of how to make it.
before using the cnc it takes me about 1 hour to make drill sand assemble tweak and so on to get one going.
now i can cut enough out to make it so i can have enough pieces cut so i cannot keep up with the cnc cutting on assembly.
have fun
999 minutes
have fun mowing down card houses and all sorts of things. get around 24 bands per load.
i have done 32 on 1/4 inch side plates and it snapped the plates. 24 is where i would stop. it can hold more but be warned!
