"GamePig" Fightstick for my "Struggle Stick"
26 opens
5 copies
436 downloads 1 comment
Chris Raynes
Chris Raynes
Massachusetts
An alternative top for my “Struggle Stick” Easel Power Hour fight stick. You can’t use this without a shell for it, or can…I don’t know your life.
This project requires a Pro Easel account as well a 90 degree V Carve bit.
Without it you won’t get the detailed Shodan carve. 8 Button Sega layout.
$5.99
Carbide Tip Straight Single Flute - 1/4 in Cutting x 1/4 in Shank
Cutting Diameter: 1/4 in, Cutting Length: 7/8 in, Shank Diameter: 1/4 in
$18.20
Carbide V-Bits
Carbide V-Bits
Cutting Diameter: 1/4 in, Tip Angle: 90 Degree, Shank diameter: 1/8 in
$21.40
Hard Maple
Hard Maple (×2)
6" × 12" × 1/2" Hard Maple
$17.72
$63.31
button_screw_rounded_cutout.svg
round cut out for button bolts
hole for the joystick
This top is made for my "Struggle Stick"
44 minutes
Directions are in Easel notes. 30mm short barrel buttons (I suggest something like seimitsu-PS14GN or similar). Also a 24mm button same specs. Have fun.
Teresa Jo Parsons
Looks great! Would you be willing to make the project public?
Teresa Jo Parsons
