Geometric Corian Dishes
563 opens
163 copies
8 comments
Ben Uyeda
Ben Uyeda
Joshua Tree, California
i carved these dishes out of 1/2" corian
Conal
First, I obviously came from YouTube :), just here to find out the size of the bit (diameter) and the thickness of the material as I want to do a Mortise and Tennon joint in the project
Conal
Sophia Goehner
I have a question: I'm assuming you needed to carve both sides of the corian. How did you do this? Did you just turn the Corian over?
Sophia Goehner
Zach Kaplan
Hi Sophia if you want to do two sided carves you flip the material. In order to flip and center your work you need to have a way to align or register the work. If you make 2 holes that are symmetrical to the design and carve them into the wasteboard then use two pins to line it up on both sides.
Zach Kaplan
Zach Kaplan
Hi Conal, Looks like Ben used a 1/8" bit 1/2" Corian material. https://www.inventables.com/technologies/white-corian
Zach Kaplan
Dara Sariaslani
I've been wanting to do projects with Corian, but I am having a hard time finding small pieces of white Corian from local hardware stores or countertop fabricators. May I ask where you get your supply?
Dara Sariaslani
Ben Uyeda
i buy it from Inventables :)
Ben Uyeda
Ben Uyeda
Ben Uyeda
eddie hall
can i have a diagram re flipping the corian to carve both sides i cannot get my head around Zac;s explanation thanks
eddie hall
