Grandchild Birdhouse With Name
Martin Gutzmer
Martin Gutzmer
Rural Bishop Hill , USA
This is a fun little project made with 1/4 inch plywood
Parts align easily and glue together along the tabs.
Bird house is finished with a piece of dowel or twig.
And held onto a tree branch or other location with a cord through the center holes
cut pieces, sand and glue
Stuart G
Would you mind sharing the easel files?
Stuart G
Martin Gutzmer
How do I share the files other than you opening it, and making a copy?
Martin Gutzmer
Neil Scott
no way to copy the project??
Neil Scott
Martin Gutzmer
Neil, simply open the file, then rename it, try that please
Martin Gutzmer
Jud Niven
There's no selection to "open in Easel"
Jud Niven
Matthew Blake Stranacher
easel has the box maker in apps and mo has a really good video that tells you how to do this
Todd Eaton
It should offer you to publish it, that will share it for us to use.
Todd Eaton
Brandon Smith
all you have to do is.. when this is opened up in easel. click the file tab on the top of the screen then click the publish and follow the steps to upload the file
Brandon Smith
Jeff Sweeney
are you still help up on publishing this?
Jeff Sweeney
