Light Guide Acrylic Sheet |
Dimensions: 8 in × 12 in, Thickness: 1/4 in |
$15.94 |
Add to Cart |
$15.94 |
59 minutes
The first step in creating your own holographic light stand for your Google Home Mini is cutting out the design from Lucite. Lucite is a type of acrylic that is specifically formulated for transmitting light. The holographic stand is an application of edge-lit signage and Lucite works great for this purpose. If you don’t have Lucite, clear acrylic works as well.
Using your X-Carve or Carvey, cut out the design using the default settings from Easel:
2 minutes
Assembling the stand is extremely easy. The two parts, the Upper Frame and Lower Frame simply slot together. After placing your Google Home Mini in the center of the Lower Frame part, place the Upper Frame on top. The LED lights on the top of the Google Home Mini should be directly under the Upper Frame.
Rene Pedersen
Bjarne Tondersen
Tim Shilson
Erik Nauman
Troy G
