Interlocking Shelf/Console
15 opens
3 copies
A TV Shelf/Console type design. Cut on the X-Carve Pro out 1 4×8 Cherry Plywood sheet.
Materials
I used a straight 1/8" bit and 3/4" plywood. The slots are designed to fit .70" thick material.
After cutting, I sanded off the tabs and edges. Assembled before painting to ensure fit.
Used primer for painting but still needed a couple coats. I used test sample paint jars to save $ on paint.
After painting, the fit was snug so you may need to sand the slotted edges.
