40% Light Transmission White Acrylic Sheet |
Dimensions: 8 in × 12 in, Thickness: 1/4 in |
480 minutes
Using the link provided and your preferred color and/or material, cut the pattern using your Carvey.
Remove the finished cut panel from the Carvey and prepare to cut the main design out from the surrounding remaining frame.
Use small suction cups or another hanging solution to attach the panels to your window. The natural light reflects through the translucent materials. Arrange the panels as you wish to create different displays!
The suction cups used here were purchased on amazon.com: 12 Tiny 7/8" Suction Cups
Jason Basquez
