LED Incandescent light bulb
49 opens
2 copies
351 downloads 0 comments
Michiel Vrolix
Michiel Vrolix
I made this lamp for the “Easel Power Hour”-challenge. It is a modern interpretation of Incandescent light bulb, and uses led bulbs (5mm, very common). I do not have a CNC machine yet so I can not test this design yet I hope I can do soon. It is made out of cast acryllic and wallnut.
Clear Acrylic Sheet - Cast
Dimensions: 12 in × 24 in - 2014 - 2019, Thickness: 1/2 in, Material Type: Cast
6" × 12" × 1/2" Walnut
this is a possible electric scematics one could use to wire the LEDs
carve everything
35 minutes
cut everything on the cnc and sand if needed.
assemble
3 minutes
slide acrylic pieces togeter, glue circles togeter and slide over acrylic also insert the leds
