Love Bus
272 opens
42 copies
708 downloads 6 comments
MINIMAL
MINIMAL
Chicago, USA
Surf’s up! Made with good vibes by MINIMAL, the team that designed the Carvey machine for Inventables.
Baltic Birch Plywood
Baltic Birch Plywood (×2)
18" × 24" × 1/4" Baltic Birch Plywood
Black Acrylic Sheet
Black Acrylic Sheet
Clear Acrylic Sheet - Cast
Dimensions: 8 in × 12 in, Thickness: 1/4 in, Material Type: Cast
$5.99
White Acrylic Sheet
White Acrylic Sheet
$5.99
MNMLBUS-flat-cut_wood01.svg
cut from 1/4" wood of your choice
MNMLBUS-flat-cut_wood02.svg
MNMLBUS-flat-cut_white.svg
cut from 1/4" white cast acrylic
MNMLBUS-flat-cut_clear.svg
cut from 1/4" clear cast acrylic
MNMLBUS-flat-cut_black.svg
cut from 1/4" black cast acrylic
Purchase Axles and Axle Caps
Purchase Axles and Axle Caps from McMaster-Carr
Part# 2025K1
2-each
1/4" Dia. 3" overall length Stainless Steel Axle Shafts
link
Part# 94802A120
1-pack of 10
Push Nut Cap for Unthreaded 1/4" axle shafts.
link
Cut Path Setup
Setup proper material and bit for each cut.
Cut Files:
Wood01 – .25" Birch Ply , 1/16 2FL FishTail
Wood02 – .25" Birch Ply , 1/16 2FL FishTail
White – .25" Opaque White Acrylic , 1/16 2FL FishTail
Black – .25" Opaque Black Acrylic , 1/16 2FL FishTail
Clear – .25" Clear Acrylic , 1/16 2FL FishTail
Cut Out All Parts
240 minutes
Switch out material and setup cut files for the all six cuts.
(see step 2)
Finish All Parts
120 minutes
Sand, polish, and finish all parts to desired level.
Glue Up Wheels
Apply a thin layer of JB Weld, Super Glue, or a strong adhesive of your choice between each wheel and tire. Clamp work together and let glue set.
Assemble Bus Chassis
Starting with the back axel, press fit axel cap to one end of the axel. Add a wheel and place on to chassis center board. Add second wheel and cap off with a second axel cap. Repeat steps for the front axel.
Assemble Bus Layers
2 minutes
Add each layer of the bus in order to create a gradual profile curve.
Add Surfboard
Press layers together and insert surfboard to lock layers together.
Eduardo Saez
Looks awesome!
Eduardo Saez
Paul Munger
Hey there. All your files are locked somehow. Ive tried running them through illustrator cs6 multiple ways, as well Every link to files except the first one are either just pictures in another browser window or not shared publicly???.
Paul Munger
MINIMAL
@paulmunger Thanks for pointing that out! We fixed the sharing settings and files are now unlocked. If you want to download the SVG files you can right click on the link and choose “download file”, then they should open in illustrator. Thanks! MNML
MINIMAL
Glenn Golden
I like this project but the black file and the download zip file are having issues. The black easel file says it is not public and the zip file is not found. Just FYI.
Glenn Golden
Benoist Cottigny
Bonjour, Joli travail. Je n'arrive pas a ouvrir le fichier noir il n'est pas partagé en public. Je débute dans la cnc et j'aimerais réaliser le projet. Merci d'avance. Benoist.
Benoist Cottigny
Joel Effinger
This project looks great! But the black file says it hasn't been made public. Is it possible to get that last file released?
Joel Effinger
