This hanging lamp is made almost entirely with the X-Carve. The ribs are made with 6mm Baltic Birch plywood and the top and bottom rings are made with Cherry though the rings could also be carved from the plywood.
See full video here:
https://www.youtube.com/watch?v=pSVGHneNoPs
** The author's moral rights;
I love this.
John McWhirter
