Mayan Calendar
2359 opens
912 copies
14 comments
Debbie & Steve Lee
Debbie & Steve Lee
Athens, Canada
We sell a straight bit version of this on our Etsy shop, so we thought we would give it a shot with a vbit, cut out the circle with a band saw and then painted it with rock paint.
Way faster cutting the sign with a vbit and a much nicer look!
George Biskitjoglou
Hello, The design is fantastic. I tried several times and with different computers but easel hangs up when I try to simulate the specific design. Did you experienced the same issue? thanks George
George Biskitjoglou
Debbie & Steve Lee
Hi @george-biskitjoglou Inventables made some performance improvements to Easel and it turned up an error in the design. If you get the share again it should be fixed. I was able to cut another one on Friday.Let me know if that fixes it for you, if not I will copy it an create another share.
Debbie & Steve Lee
Ben muniz
I had the same problem 2/15/18 help?
Ben muniz
Mark D Tetrault
Mine suffers from the vbit not touching the board in all spots. I cant understand why. I am very careful about homing and all but it still seems to miss a lot of the detail while carving. Ideas?
Mark D Tetrault
Debbie & Steve Lee
There are many reasons why this might happen (material not the same thickness, z-probe out slightly, waste board not level to the z-axis), maybe ask in the forums or you can send a tech support request through Easel. Good luck!
Debbie & Steve Lee
Greg Purl
I only get the circle, no design at all. wanted to try to make a smaller one to inset in another project.
Greg Purl
Debbie & Steve Lee
There are two work pieces one cuts the sign into a circle the other cuts the actual design.
Debbie & Steve Lee
Bill McAllister
Only thing that opens is the circle
Bill McAllister
Debbie & Steve Lee
Debbie & Steve Lee
Greg Murray
Like.But total waste of my time.Will not generate tool path??
Greg Murray
Greg Murray
My bad, Selected wrong tool bit for this job.All good!
Greg Murray
Clint w Richmond
My machine did a horrible job, did not follow the path correctly.
Clint w Richmond
Svend Larsen
Whee do I find the second part of the design?
Svend Larsen
