McGinn's Famous Star Spinner!
Jason McGinn
Jason McGinn
Cocagne, Canada
These fidget spinners are cut from 1/4" Layered HDPE, but could be used with any material at the same thickness. The caps and the spinner were designed for ABEC 608 Bearings.
Sealed Bearing - 8mm x 22mm x 7mm
ID: 8 mm, OD: 22 mm, Thickness: 7 mm, Type: 608-2RS
$6.49
Two-Color HDPE - Red on White
Thickness: 1/4 in, Dimensions: 8 in × 12 in, Quantity: 1
$6.80
$13.29
McGinn_s_Simple_Spinner_0625EndMill_70ipm.nc
G-Code File
19028231_129657137612044_5283070061983039488_n.mp4
Little video clip on one put together.
Make the parts on your machine
2 minutes
Place your layered HDPE or other material on the machine giving 2.5" by 3.5" space.
Using a 1.6mm or 0.625" fishtail end mill, run the easel project or load the g-code and run.
Finishing work
Using a knife, clean off the tabs.
Using a DIRESTA Ice Pick or a throwing dart to clean the inside detail track if needed.
*Optional for performance.
Using a DIRESTA Ice Pick or a throwing dart remove the cap from your bearing and clean your bearing using Acetone or Mineral Spirits (gets the thick grease out)
Let air dry, pressure fit into Spinner
Pressure fit caps into bearing, align bearing up and down and spin.
If you wanted to stop movement, simply add a dab of CA glue to the bearing before press fitting.
