MWP 0-9 Dominoes, 55 Tiles
1145 opens
439 copies
5 comments
Robert Rieke
Robert Rieke
Los Alamos, NM
A set of 55 dominoes numbered from 0-9
Acquire Desired Wood
You can make this project out of any thickness and size of wood, but I designed it around maple hardwood flooring scraps I had after overhauling my house. I chose to use it because:
1. The layers of ply give the sides an interesting look.
2. The front was already finished, so no finish is required.
3. The back didn’t have any marks that would show through a coat of paint.
The wood I used had a useful cutting area 3.5 inches tall, and was 0.390 inches thick.
Paint Back of Wood
To keep players from recognizing pieces by the wood pattern, you should consider painting the back of the piece of hardwood flooring. We chose high gloss hunter green.
Be sure to let the paint fully dry for at least a day before setting it on the wasteboard and cutting. Failure to wait could result in a little bit of paint transfer to your wasteboard (and the subsequent dust sticking to the painted pieces). Uncured paint can also gum up your bit and mark up the sides of the pieces, which requires a lot of sanding to get rid of.
Cut the Dominoes
180 minutes
I have the Dewalt 611, and used these settings:
Bit: 4 flute upcut, flat end
Dewalt 611 speed: 2
Depth of cut: .040 inches
Feed rate: 80 inches per minute
Arrange the dominoes in the Easel project file as necessary for the size of wood you are using. For dominoes that are not part of the immediate cut, you can do one of the following:
a) Make a copy of the project for each piece of wood, and erase the dominoes that won’t be included
OR
b) Set the cut depth of all other dominoes to 0 inches/mm.
The shapes/figures were all cut 0.075 inches deep so the bit would cut completely through the first ply.
Sand Dominoes, and Round Edges
This is the part that everybody hates. The dominoes will likely have tabs that need to be cut off and the sides may need a little bit of sanding.
Don’t forget that there may be little hands playing with these parts, so I highly recommend that you round the edges slightly so there aren’t any sharp edges. You don’t need to go nuts, just spend a little bit of time with a piece of 220 grit sandpaper and you’ll be good to go.
Go Play Dominoes
Play dominoes with whatever rules you want. Don’t forget to add house rules, since like in Vegas, the house must have at least 50/50 odds of winning. :)
Zach Kaplan
Cool! Is it easy to see the dots in person?
Zach Kaplan
Robert Rieke
Thanks! The dominoes are 1.5"x3", so the closeup picture is almost life-size (on my screen). It's pretty easy to see them since the wood has a high gloss finish, but it may work even better to put a drop of thick paint into each of the dots.
Robert Rieke
Willmen R Kwok
great project and its on my list of things to make.. I'm designing a chicken foot board and will make it to fit these. watch for it.
Willmen R Kwok
hannes jan
Ik ben nog een beginneling maar wil dit wel eens proberen. Maar hoe kan ik dit met de verschillende dieptes allemaal instellen.
hannes jan
Don hoverson
any plans for 15 mexican train dominoes?
Don hoverson
