MWP Spindle Mount for Dial Indicator
Robert Rieke
Robert Rieke
Los Alamos, NM
Whether you want to calibrate your Z-axis or verify your table is truly flat, a good high quality dial indicator works wonders. This project will show you how to make a mount for the dial indicator that attaches to the spindle holder.
Button Head Cap Screw
$3.49
Flat Washer
Flat Washer
Finish: Black Oxide, Dimensions: I.D: 5.3mm; O.D: 10mm, Quantity: 10
$4.00
Hard Maple
Hard Maple
6" × 12" × 3/4" Hard Maple
Threaded Inserts
Threaded Inserts
Size: M5 Dont use, Quantity: 100 Dont use
$7.49
Modify design in Easel to fit your dial indicator
I designed this to fit my dial indicator mount, you may have to modify the size of the circles in order to fit your specific model.
The cutout is designed to minimize rotation of the dial indicator around the screw, and is composed of both a circle AND a square. Be sure to change the size of the square to match the diameter of the circle.
Mount material on X-Carve and carve
Choose the material you want to make this from and mount it on the X-Carve. I made my prototype out of 3/4" MDF, and the final product out of 3/4" maple.
Drill larger hole and attach threaded insert
Using a hand drill or drill press, drill the hole on the “right” side (side opposite notch) to 5/8" or 11/16", then screw in the M5 threaded insert.
If you plan on applying a spray finish, you may want to wait to screw in the threaded insert until after the finish is dry.
Sand and finish as necessary
I prefer the raw material look, but sand loose fibers and sharp corners and finish as desired.
Attach dial indicator, then attach to spindle mount
Using (1) M5x25mm bolt and washer, attach the dial indicator to the mount. Then use (2) M4x30mm bolts and washers to attach the mount to the spindle mount.
Moulton Designs
Hey Robert, are you able to post your file? I'm not quite following how you attach this to the router collet
Moulton Designs
