Pentagon Hot Plate
The Guru
The Guru
In honor of memorial day, a Pentagon hot plate/cutting board with wood inlays.
$5.99
Hard Maple
Hard Maple
6" × 12" × 3/4" Hard Maple
Padauk
Padauk
6" × 12" × 1/8" Padauk
$8.47
6" × 12" × 1/8" Walnut
$9.09
$23.55
pentagon_main_pocket_35.nc
Main Top Pocket
pentagon_outside_35.nc
Pentagon Outline (0.9 deep)
pentagon_ring13_35.nc
Walnut Rings
pentagon_ring24_35.nc
Padauk Rings
Main pocket
Attach wood to cutting surface using double sided tape.
Zero machine
Load gcode – main pocket – and start machine.
Outline
Load outline file (pentagon_outside_35.nc) and cut outside of board.
Remove board from cutting surface when complete and discard leftover pieces.
NOTE1: 1" or greater cut length on router bit is required.
NOTE2 – maintain board orientation after removing. Otherwise, when you add the overlays you will have to rotate everything until it lines up.
Walnut Rings
Attach walnut to cutting surface using double sided tape.
Zero machine
Load ring13 file and start machine.
Carefully pull up rings when complete.
Padauk rings
Attach Padauk to cutting surface using double sided tape.
Zero machine
Load ring24 file and start machine.
Assemble
Place inner most ring on main board.
Continue placing rings by working outward until complete
Sand and Finish
Sand with 100, 150, 200, 400 sand paper until smooth.
Finish with a coat of bees wax or your favorite polish.
