Pint Glass Display Rack
171 opens
77 copies
2 comments
Steve Carmichael
Steve Carmichael
MONROE, GA
I made this display rack for my Hard Rock Cafe pint glass collection. It holds 21 glasses and can be personalized for gifts.
Easel Bit Set
Easel Bit Set
Set of 4 bits that can be selected in Easel for simple cut settings
$33.09
$33.09
Watch the Video!
6 minutes
Check out my video of this project, then make a Pint Glass Display Rack for yourself or someone else. Don’t have a pint glass collection? Start one!
Prepare the Wood
Cut two blanks that are 29″ × 11.25″ × .75″ and mount one on the X-Carve.
Cut the First Set of Parts
90 minutes
Verify the thickness of your wood and adjust settings if necessary.
Edit the text as desired to customize the sign for the top of the display rack.
This work piece includes one shelf, the left side, and the sign.
Cut the Second Set of Parts
90 minutes
This work piece includes two shelve and the right side.
Sand the Parts
45 minutes
Take your time and sand all of the parts smooth. A variety of sanding tools and some good music make sanding a bit more bearable.
Paint the Sign
Mask off the areas around the text and spray paint the letters with your desired color.
When dry, peel off the tape and sand away the paint on the surface.
Vacuum the dust out of the letters.
Assemble the Rack
Insert the shelves into the dado grooves on the side pieces, with the circles facing the top.
Drive screws through the sides and into the shelves.
Position the sign so it is straight and flush with the back and top of the rack.
Drive screws through the sides and into the sign.
Finish as Desired
I suggest using Deft Clear Wood Finish Spray Lacquer to seal the wood and provide some protection. It dries really fast so you can get the rack mounted and filled with glasses in no time.
9
Enjoy Your Pint Glass Collection!
Sit back and admire your work!
Thanks for checking out my project! Check out my other projects on my website and YouTube channel at the links below, and please follow me on Facebook, Twitter and Instagram to keep up with what’s happening in The Carmichael Workshop!
Click Here to visit my website!
Click Here to watch my YouTube channel!
