Remake of "DIRESTA Wood Stool "
29 opens
14 copies
3 comments
Adam Norris
Adam Norris
North Ridgeville, OH
I modified my design for my one-year old son. Using 1×12″ pine board I was able to fit three stools onto one 10 foot board.
Design
I imported a hand drawn image into Inkscape and then turned that into a usable .svg for Easel.
Cut Stool Top
Cut the stool top out first. I started with my design using a 1/8" bit and then flipped it over and used a 1/4" for the rest of the cuts. I marked the center of each side and used the origin in Easel for the home position.
Cut out Legs
17 minutes
Cut the legs out two at a time. I had to go back and modify the center cuts slightly so they were oversized enough for a snug but easy fit.
Finish & Assemble
I used a router table to round all edges. Then used several coats of a lighter stain. Assemble, glue up and enjoy!
Bob Canning
This project is not shared publicly. Is it available??
Bob Canning
Daniel Harasim
Public??
Daniel Harasim
Anita Chang
03/25/2021 - Would you mind sharing this? Mahalo!
Anita Chang
