Remake of "Z-Probe Holder"
Casey L Eberly
Casey L Eberly
A small box, that can be permanently attached to the X-Carriage to stow the Z-Probe (puck and alligator clip), while the plug of the Z-Probe can stay plugged in.
Same design as the original except this one is made on a 3D printer and modified to work with the dust boot.
ZProbe_Box.f3d
ZProbe_Box.stl
Generate GCode and Print
330 minutes
Open the STL file in your favorite slicer, generate the gcode and print. I printed at 0.2 mm layer height, 10% infill, 50 mm/s.
Note
I included the Fusion 360 file, if you want to play around with the model. One thing to note is the mounting holes are a bit off and need to be moved in the model or filed out.
