Rotating modular RC car stand
45 opens
15 copies
HemiStorm RC - Chris de Graaf
Halden, Norway
This is a very easy to make RC car stand, fully modular to enable you to adapt it to your needs, and (dis)assemble it without the need of any tools. It features two separate trays and a rotating top platform. Low cost, ease of use and convenient transport were key when designing this project.
Black ABS Plastic Sheet
Dimensions: 12 in × 24 in, Thickness: 1/4 inch
$16.00
$16.00
Carving the ABS
Make sure your sheet is lined up perfectly because the design as posted does not leave a lot of room around the cut pieces. It consumes the entire sheet of ABS. This project is extremely straight forward.
Making the pivot point
Glue the larger ring to the underside of the rotating platform using some CA glue. The smaller ring is a direct fit inside the larger ring, and should be fixed to the platform with the four connectors using a nut and a bot, M3x16mm or longer.
Slot parts together
2 minutes
This step is the easiest and most rewarding of the project. A very straight forward design, slot the lower braces in the both sides and hook the top plate with the hooks into place. Push the four keys in the holes above the lower braces to stiffen the structure, drop the top platform on the box and you are done! An easy to assemble and disassemble RC car stand.
Made one? Log in to add yours
