RPG Dice Box
545 opens
229 copies
12 comments
Ken Howard
Ken Howard
Vancouver, USA
I’ve made these from 3/4" UMDF, Black Walnut, and Purple Heart Wood so far. The shallow holes in the corners are for 8mm x 3mm magnets (available on Amazon) to hold the two pieces together. I rounded over the outer edges on my router table. I’ve also carved designs on the outer halves as well.
Chris Knuckles
Great idea! I’m going to work on a couple of these this weekend
Chris Knuckles
Jeff Davidson
Looks great. I’ll be making some as well
Jeff Davidson
Ken Howard
Would love to see how yours came out! You can tag us on Instagram as @voodoodaddydecals to share. I've also got more pics of the process and progress of these and other things I make in my spare time.
Ken Howard
Ken Howard
Also, here's a link to the magnets I used. They come in a package of 100. https://www.amazon.com/gp/product/B07B3SDRCP/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Ken Howard
Kurt Canez
Is the underside of the lid just flat?
Kurt Canez
Ken Howard
No. The lid is a mirror image of the bottom. Each half is 3/4” think, and carved 1/2” deep, giving a 1” space when closed, and allowing you to do a 1/16” or 1/8” deep carving in the outside of the lid, for decoration purposes.
Ken Howard
Ken Howard
No. The lid is a mirror image of the bottom. Each half is 3/4” thick, and carved 1/2” deep, giving a 1” space when closed, and allowing you to do a 1/16” or 1/8” deep carving in the outside of the lid, for decoration purposes.
Ken Howard
William S Searles
Great design! I've had a lot of enjoyment using this as a template!
William S Searles
Paul Santellana
Do you think the character tray would be big enough to support as a dice tray? Add felt to bottom?
Paul Santellana
Ken Howard
Paul, The minis section is the same depth as the dice spots, and I use mine to store more dice instead over lots of minis. Mine is lined with felt too. As far as using it as a dice rolling tray, it is a bit on the small side for that, but could be used in a pinch.
Ken Howard
Ken Howard
William, Thanks so much! This was the first dice box design that I made, and there are quite a few others that I’ve designed for my Etsy shop.
Ken Howard
Ken Howard
Would still love to see how all of yours came out! You can tag us on Instagram as @VDX_Designs to share. In addition, you can visit my Etsy shop at VDXdesigns.etsy.com to see how this design evolved over the past few years.
Ken Howard
