I made a Rustic aged looking Harley Davidson sign. Done mostly with the X-Carve CNC Router. Using a 90* V-Bit to cut scratches, lines and dots into the wood. You can check out the video of this on youtube:https://youtu.be/umipxMWLK4w
The author’s moral rights;
