Thermoforming (AKA heating then bending) corian has been something that interested us for a while and it was SO FUN!! It really paired well with CNC milling via our X-carve. These salad servers definitely won’t be the last of this project type.
** The author's moral rights;
corian is pretty awesome material.. but very espensive! around 500- 700 dollars for a 4'x12' sheet, depending on color and grade.
Andrew Smith Milan
