Shapeoko 2 Mechanical Kit to Full Kit
Sam Alaimo
Sam Alaimo
All of the parts needed to make your mechanical kit to a full kit. DOES NOT INCLUDE the spindle and tools. This does not include the Power Pigtail (30313-01) — Connector/Adaptor: 5.5 mm x 2.5 mm Barrel Male Plug. See http://www.shapeoko.com/wiki/index.php/Parts#Electronics for further details.
24v Power Supply (90w)
Type: Power Supply, Output Voltage: 24 VDC, Input Voltage: 100-240VAC @ 50-60Hz, Output Wattage: 90W
Aluminum GT2 Pulley - 20 Teeth, Dual Flange - 20 mm Pitch
Aluminum GT2 Pulley - 20 Teeth, Dual Flange - 20 mm Pitch (×3)
Bore: 5 mm - 2013 - 2019, Belt Width: 6 mm
Arduino Uno
Arduino Uno
Arduino Uno w/ Grbl CNC 1.0c
Mechanical kit (requires you provide electronics, pulleys, belts, and M3 hardware to function)
$300.00
Flat Washer
Flat Washer (×2)
Finish: Zinc Plated, Dimensions: I.D: 3.2mm; O.D: 7mm, Quantity: 10
$4.00
gShield
gShield
gShield
GT2 Belting - Open Ended - 4 Meters
GT2 Belting - Open Ended - 4 Meters (×6)
Width: 6.35mm - don't use, Pitch: 2mm - don't use
Hex Nuts
Hex Nuts
Height: 2.4mm, Pitch: 0.5mm, Quantity: 10, Width: 5.5mm, Thread Width: M3
Power Cord
Power Cord
Length: 3 ft, End 2 Type: EIC 320-C13 - 2012 - 2019
Socket Head Cap Screw - Packs of 10 each (×2)
Length: 8mm - 2012 - 2019, Quantity: 10, Thread Size: M3
Length: 12mm - 2012 - 2018, Quantity: 10, Thread Size: M3
Stepper Motor - NEMA 17
Stepper Motor - NEMA 17 (×4)
Lead Time: In stock, Holding Torque: 62 oz/in
Stepper Motor Cable
Stepper Motor Cable (×15)
Length: 1 ft, Category: Accessory, Type: Cable
Terminal Block
Terminal Block (×3)
Positions: Terminal Block 4
$14.97
$318.97
Does not include the Power Pigtail (30313-01)
Please note that this does not include the Power Pigtail (30313-01) — Connector/Adaptor: 5.5 mm x 2.5 mm Barrel Male Plug. See http://www.shapeoko.com/wiki/index.php/Parts#Electronics for further details.
William Adams
Please note that this does not include the Power Pigtail (30313-01) -- Connector/Adaptor: 5.5 mm x 2.5 mm Barrel Male Plug. See http://www.shapeoko.com/wiki/index.php/Parts#Electronics for further details
William Adams
Sam Alaimo
Thank you will!
Sam Alaimo
Manuel Caceres
I thought that the shapeoko 2 is dual drive by default, only see 3 Aluminum GT2 Pulleys,etc.
Manuel Caceres
Manuel Caceres
Never mind. For some reason i thought you needed 4, I am wrong. 2 for dual y and 1 for x. disregard my comment.
Manuel Caceres
Mike Eubank
The GShield is no longer available for purchase?
Mike Eubank
Sam Alaimo
Hey Mike, The gshield is temporarly out of stock.
Sam Alaimo
Bennett Sampson
Thank you so much. I had ordered the mechanical kit thinking I would order the electronics later, however I was so confused with what to get. Then I stumbled upon your list and bought it immediately. Thank you so so so so much!
Bennett Sampson
Andrew Ryan john
What's the best software to use with it ?
Andrew Ryan john
richard alexander salvador natividad
Buenos días soy de lima - Perú quisiera saber como puedo hacer para comprar todo el kit y sobre la programación del arduino ya viene programado disculpas por que mi comentario esta en español le agradecería su respuesta
Brandon St.Rose
i know i'm late but i'd like to build this, where can i get a replacement or an alternative to the cnc milling kit,since it's no longer available, the x-care is too expensive for me.
Brandon St.Rose
Sam Alaimo
@brandon, your best bet will be to contact the "customer success team":https://inventables.desk.com/ or talk to the public on the "forum.":https://discuss.inventables.com/
Sam Alaimo
Marcus
Is this all I have to purchase to build this? Also does it come with instructions?
Marcus
Jing Lin
I purchased a full kits of Shapeoko2 in 2014. Now I need to use different PC to control it but I for got where I can download the software to control it. Could you please send me the link?
Jing Lin
