Shaving Brush & Razor Stand
John McWhirter
John McWhirter
Chicago, USA
A classy shaving brush and razor stand in tortoiseshell acrylic. The stand your grandpa would make—if your grandpa had a laser cutter. Accommodates most double-sided razors, and brushes with 1-inch or smaller handles (at the smallest point) Requires a plastic bending machine.
Tortoise Shell Acrylic
Brush_Stand_Blank.svg
Add your own engraving or vector cut design.
Brush_Stand_Chicago.svg
As pictured, with a classic 6-pointed Chicago star.
Download Files
Choose the blank pattern if you want to add your own design or keep it simple. Choose the Chicago star if you want to rep’ the Windy City.
Cut!
The outline (and the star if you chose the Chicago model) should be vector cut. There are two horizontal lines in the file which mark where to bend the stand, they can be lightly engraved or deleted if you’re confident in your bending skills.
Bend!
I recommend bending it against something square to get the angles right.
Shave!
Enjoy a luxurious wet shave every morning with the confidence that your brush and razor will be properly stored when not in use.
