Simple Sign
87 opens
18 copies
Tait Leswing
Tait Leswing
An easy sign project to get you carving quickly
Blue Expanded PVC Sheet
12" × 12" × 1/8" Blue Expanded PVC Sheet
$2.05
$2.05
Step 1: Material Setup
Clamp your material down on all four corners like this:
Step 2: Install your bit
Slide the bit that came with your machine into the spindle and tighten it like this:
Step 3: Machine Setup
Gently move the bit to the origin. If it’s hard to move check to make sure that there is no power to your machine.
Step 4: Easel
Power up your machine and start designing in Easel. When you’re satisfied with your design click “Ready to Carve” in the upper right hand corner and follow Easel’s instructions. Don’t worry about the material and bit measurements, they’re preset to the correct values.
