Six Pack Bottle Holder
1848 opens
736 copies
2522 downloads 27 comments
Ed Shouse
Ed Shouse
Using Easel’s box maker/dogbone generator to create a 6" wide by 4" high by 10" long box with holes cut out for beverages and a handle. Customize the four sides of the box with any personal message or leave blank. The sides of the box are 1/4" cherry and the handles is 3/4" oak.
Cherry Wood
Cherry Wood
Red Oak
Red Oak (×2)
6" × 12" × 3/4" Red Oak
$6.49
$6.49
Handle Final Design.svg
Handle for six pack beverage holder
1. Add Design to Easel File
Add images, text etc to to the sides of the box. Be careful not to get to close to the edges since you still want the box to have strength. Measure thickness of the board you are using for the handle and change the the width of the rounded rectangles to match. Make sure when you make this modification doesn’t change the center of the holes. If you aren’t going to round over the handles or the box then remove the rounded corners.
2. Cut Out Pieces
Cut out all the pieces of the box out of 1/4" wood
Apply Finishing
100 minutes
I suggest painting prior to assembly of the box for ease. After you finish painting glue the box up. With the box together without a handle, use a round overbit on a router on all corners include the handle. This gives a much smoother feel to hold onto. Now glue up the handle and apply final stain/poly.
David Shoemaker
This is so cool. Love the design and simplicity of it. I have my machine on order and this is definitely one of the projects ill be doing.
David Shoemaker
John Zulick
You did awesome job on the bottle carrier. I was able to make the carrier fine But could not download the handle.
John Zulick
Ed Shouse
John the SVG for the handle is in the digital files. you need to import it to a file and pay attention to the stock that you cut it on to match the holes. I used 3/4" oak for mine.
Ed Shouse
Steen Mogensen
hey Ed could you make an svg file on the hole design. I have Mach3 and i´m not able open it:-)
Steen Mogensen
Chris Von Bargen
Issues I'm having with the .SVG file for the handle: Open in Easel and it is only a fraction of the size it should be. Open in Fusion 360 is has the same problem. Open it in Inkscape and it appears normal but I can't modify it. Suggestions?
Chris Von Bargen
Chris Von Bargen
I was able to measure the design in Inkscape and it appears to be scaled down significantly. What scaling should be used to correct this? Any chance you could check the file and re-upload it?
Chris Von Bargen
Ed Shouse
http://easel.inventables.com/projects/oV1CkPYS0t_rfXb492wbTw here is my easal file of it.
Ed Shouse
Chris Von Bargen
Thanks Ed, the link didn't open though.
Chris Von Bargen
Chad Shelby
http://easel.inventables.com/projects/oV1CkPYS0t_rfXb492wbTw yep, ^^ didnt work for me either.
Chad Shelby
Tate Kaiser
Anyone have access to an easel project they can share? I'd like to make these for a Christmas gift.
Tate Kaiser
Jack
Here's a shared version of the handle, folks: http://easel.inventables.com/projects/6pqvunts6OdC-Un2VxW41w#
Jack
John White
I only see the SVG file for the Handle. Am I missing something?
John White
John White
Nevermind. It helps if you read everything first.
John White
Kristian Ang
I like the pattern, but.... Wher is the pattern for the handle ?
Kristian Ang
Kristian Ang
How do you attach the handle ?
Kristian Ang
Todd Warnock
Jack - for some reason your link won't open (doesn't give an error - just doesn't open. Am I missing something? I'm trying to get the handle figured out! Thanks!
Todd Warnock
Marc Nelson
Has anyone figured out the Handel yet? I see the SVG file but when I put it into easel I just get a blank file. HELP Please.
Marc Nelson
Marc Nelson
I downloaded the SVG file and I noticed the size of the handle was 0.7 X 0.7 once I made it bigger i could see it. What are the actual height and width of the Handel?
Marc Nelson
Ed Shouse
Ed Shouse
Ed Shouse
Glue to hold the handle in place. Sorry for lack of replys. Link above is the project file I used for the handle.
Ed Shouse
Ed Shouse
Apparently I didn't hit save on the share link to set it so public could see the file. See if it works now.
Ed Shouse
M Chilla
Hi Ed, Thanks for the great desing idea. I have a "silly" question. The material thickness is a bit over 1/4''. Is the 1/16'' bit able to cut through the whole material? it's 1/4''H. I'm from Spain and I work in mm, so 6,35 to 6,60 mm seems a bit too much for the bit to get to cut it.
M Chilla
Fedko
Dear Ed, thanks for the great design! Any chance of getting also the bottom part in svg or dxf format? I do not like to use Easel... Thanks
Fedko
Dominick Marino
Little confused, the instructions say to cut out all the pieces out of 1/4 wood but the Bill of materials lists only a 3/4 piece of red oak. I am assuming the 3/4 is for the handle only.
Dominick Marino
Thomas
Was there a reason why tabs weren't installed? I only cut out one side and front to see how they fit. They did not fit. The interlocking tabs were too large. I would have to take a jig saw to trim each tab. What do you think happened? Please help! Thank you.
Thomas
Christian Quintanilla
Did you cut out everything on the x carve
Joe Bell
Can't download handle design
Joe Bell
